I don’t know how the fuel pump is on a 2001, but on square bodies the ground for the pump is right next to the tank. In order to wire in a switch for the ground you’d need to extend that ground line to wherever you want the switch, I’m assuming somewhere in the cab. Easier just to put in a switch on the positive side, maybe on the coil terminal of the pump relay so the switch doesn’t need to handle much current.
