neubanksc5
Does the foam sleeve around the fuel pump serve any purpose than noise reduction? Swapped out the fuel pump today and the old sleeve came off in about 4 pieces, so just installed the new pump without one. Anyone know where I can order one?
The blazer was sitting for about 3 years. Slapped a battery in it and it cranked right up. Ran good for about 45 minutes then sputtered and died. It would fire up but die right away. After some trouble shooting, decided it was the pump. Found out it was the rubber hose between the pump and the hardline had a split in it, same problem many other people had here.
