Alright I’m dealing with a few electrical issues, as you can see.
View attachment 391546 There are like 3 main circuits I’m trying to get working right. Horn, windshield wipers/washer, and headlights/blinkers. I want to open a thread to hopefully get a few people on here that can help me out. The first question I have is regarding the horn circuit. Specifically the ground. So there’s an orange power wire that goes from the junction block (behind the horn fuse) to the horn relay, that gives power to the relay. There’s a green wire that goes all the way from the second terminal on the relay out to the horn. And there’s a third black wire that grounds and triggers the relay to send power to the green wire. The horn is grounded on the core support. So the ground wire goes from the 3rd terminal on the relay, straight to the steering column connector for the turn signal switch. There’s a little button in that switch that when depressed, will close the ground circuit. But I don’t know how that button is actually getting grounded. Is the steering column grounded just by being bolted in? Or is there a ground feed to the steering column somewhere? Hopefully that made sense.
