I bought a cargo van for business use. I planned to run certain equipment and appliances, including a household vacuum cleaner. As the vacuum uses 12A (1440W), I bought a large capacity inverter at Harbor Freight(2000W/4000W). I planned to install a second battery in the bed behind the driver's seat, wired in parallel with the van battery. However, the inverter directions state, "Do not use automotive, engine starting (SLI), or maintenance-free wet cell batteries with this inverter, they are designed for repeated shallow discharge and will wear out quickly." It says that marine or RV batteries are intended for this unit. How can I deal with this situation. I can always return the inverter. But, I'd like to know if it's possible to get the power I need, or if I planned something impractical. For discussion, assume half hour run time of equipment every hour, if that helps. Looking forward to good advice from the experts I have come to expect on this site. Thanks in advance.
GB
GB
