Some things that I found in my research.
Do NOT use any stainless steel in your tank. It puts off a toxin that's very bad.
Use Sodium Carbonate - 1 table spoon per gallon of water, more is not better. You can find it in a couple of products. Arm and Hammer Super washing soda, Pool and spa chemical "PH Increase"
- edit the sodium carbonate does not go bad and there is no need to change it.
Power source must be DC, some battery chargers work if they are not the smart type.
The negative lead goes to the part being de-rusted and the positive lead goes to the anodes.
Carbon makes for really good anodes.
Do this outside and do not cover the tank when in use. It puts off some very explosive gases.
Here is my build so far. A couple of rebar rings and some up rights along with some carbon bars I bought off of ebay.
