DieselWarrior
This is a youtube video from my Project: DieselWarrior, it details the modification of an XJ/Jeep Cherokee intermediate steering shaft to replace the mid section of the stock GM shaft, thus adding dual U-Joints and totally eliminating the rag joint.
The results are so impressive, I had to share.
http://www.youtube.com/watch?v=y26tFeofUfA
Pros:
-Steering box does not need to be removed
-Steering box does not need to be modified
-Steering column does *not* need to be modified
-Stock steering components are left totally stock
Cons:
-Requires welder and grinder
-Requires knowledge of welding
-Requires knowledge of metalwork
Results:
-Results are immediate! Steering is much more responsive, wandering and slop is virtually eliminated, since the rag joint is removed tactical feedback though the steering wheel is greatly improved.
Any questions, feel free to ask.
Andrew
Pros:
Cons:
Results:
Andrew
As for the rest of what you said, Ill need a translator.
