I know this information is out there, but searching here and on Google proved fruitless.
I'm getting ready to run the turbo downpipe, and I just don't like anything about running it through between AC box and head. Just no room, too close to things that don't need to get hot, and a future maintenance nightmare. So I'm looking at routing the 3" downpipe under the AC box just outside the frame rail until about 1/2 way under the AC box and then back to the inside of the frame rail to meet up with the rear pipe. Bends aren't that much more than running it down the inside, and it looks like only a minor modification of the inner fender will be needed for this.
But then I realized, the rear AC lines are roughly in that area, so I needed to mock them up along with the inner fender to see what was feasible. It seems obvious that they go up just outside the firewall rib where the inner 3/8" body bolt secures the inside of the inner fender to the firewall. But when I get on top of the inner fender, it seems like the pieces don't fit they way they should. Some of it's likely due to accidental bending while in storage, but I'm also missing dryer, condenser, and radiator shroud, so there is a lot of pieces just not locked down in final location, and no practical way to mock it up further.
So, I would really like to see what a fully buttoned up set of AC lines with rear AC should look like when complete. Where do they attach, and how the high/low lines fit alongside each other from the AC box to the core support. I also have similar "where can I put it" issues with the waste gate actuator, which if mounted stock, would put the diaphragm head on the wrong side of the inner fender, and I don't want to relocate it only to find out it interferes with the AC lines.
If anyone knows of a thread where this is shown, I would much appreciate it. Or good search terms ("rear ac" combined with various relative terms didn't pop anything useful). Otherwise, if you could take and/or post some pics, it would be much appreciated.
