Ryan B. said:Have you found ANY BBC fuel injection that can keep up with 632 cubic inches!? would be nice to have it still purring and running perfect on a sidehill.
I have this feeling its gonna need more than 1000 cfm! and i don't think BBC ramjet or edelbrock proflo was really designed for something that huge.![]()
Maybe custom built injection is what you're gonna be after with a custom built monster motor.
RB,
Nope, no idears yet on that one. In fact, fuel delivery in general is going to be a challenge. Every one of these large crate engines seems to be built with a 1050 Dominator or some other "drag race" type carb. Not exactly "4x4 friendly" if I had to guess.
My initial hope (and this is all unsubstantiated) is that by avoiding a high-HP monster, I won't need the super large CFMs from the fuel system. The DD simulations I've done were only using carbs in the 750CFM - 900CFM range....they do lose power (and torque) over the larger units, but not in a catastrophic way.
To make it even harder on myself, I don't want the "look" of a multi-port EFI system on this engine either. A "classic" truck needs a classic pushrod V8 with a "carb"-looking system on it. I figure a LARGE TBI system could probably be disguised well enough with the air cleaner to pull that one off......but a couple of shiny fuel rails running down each side of the engine, with modern plastic covered injectors and wiring loom isn't going to be acceptable to me.
If there was a way to somehow "hide" the injectors on the underside of the manifold instead of on the outside (and run all the wiring underneath and hidden too!) I could probably be convinced to do that.....I've never seen it done, and I'm not sure I could afford to have someone develop that solution for me.....
So many things to figure out.....good thing I've still got a couple of years left.
