When the roof is extended on the camper are you able to stand in the back of the K5?Yes on both. The one currently on my Crawlabago also has a radiant style propane heater but the other two I have both have forced air propane heaters.
Yes but I'm a bit vertically challenged. 5'8"When the roof is extended on the camper are you able to stand in the back of the K5?
I’m 6’ tall and the nub of my hat just barely touches the roof if I really stretch out. I do have a 1/2” rubber bed mat on the floor that puts me a little closer too.Yes but I'm a bit vertically challenged. 5'8"
I think @ZooMad75. has to duck a bit in his but he is a bit taller. 6'2" ish?
Saw a guy at Penndot lean over a dump truck engine one time and the tails of his untucked uniform shit got wrapped in the belt, luckily someone shut the truck off before he got his junk eaten by the fan….also saw a fella kneeling behind a salt spreader stick his fingers over the edge….fingers and his arm were no match for hydraulics….sure makes you take notice of what you’re doing quickI stuck my finger over the back of my fan shroud in the old Monza once, and about broke my damn fingers.
I was trying to lean over the engine and look at something on the carb.
That's how I found out you gotta stick em in from the radiator side, or straight down from the top to cut em off.
lesson learned. Once and done lol.
On my K5 the fan shroud fell towards the engine and the fan blades cut into the plastic on the shroud.I put new motor mounts in my Trans Am and it bumped the engine up, the fan cut a slot in the shroud.
