Engine mount hack
Vombrown
Mountain Man
Great Falls mt
please for the love of all that's holy.....
If you install motor mount bolts that aren't welded to the mount, tack weld the head of the bolt to the mount. Someone, sometime will have to take them out and he will be cussing you like a sailor as he struggles for two hours to remove six bolts. I know I'm not the only one that does this.
never seen a 73-87 style factory with welded nuts to the mount . . .
and try doing 88-98 2wd style . your best option is basicly take the coil spring out to get to them . unless your real good and have a lift and a extra set of hands.
