Lol, unfortunately without them the bolts are too longEasy. Don’t put em on.
Thank you sir, you are correct the bolts are too long without them. Ask me how I know, lol.those were for brace rods back in the day to lower bellhousing . they were a great idea . but we have all found over the years to much stiffness can be a bad thing . so unless you want them for show there is no need to run that setup . if you skip them make sure the 3 bolts per side are not to long and bind up before tight . might need shorter .
and if you do run them they point down and to the back for the 1 single hole for each rod .
That and the motor mount bolts will not fit without the plates in place.Thank you sir, you are correct the bolts are too long without them. Ask me how I know, lol.
