Hey all. The engine oil cooler hoses are leaking well just the bottom one however the top on looks a bit old so to be safe its going too
the hard lines look good so just the hoses need to be replaced. I got some from napa but they were not the right ones. The hose length was way off and the bends on the tubes were different. I forget the part numbers but thats all they showed.
So any thoughts? I Dont need the hard lines that go across the radiator. Just the hose and fittings that attach at the filter .
Also I read something about upgrading the hoses but it didnt say what to upgrade to.
It a 84 diesel, thanks in advance
the hard lines look good so just the hoses need to be replaced. I got some from napa but they were not the right ones. The hose length was way off and the bends on the tubes were different. I forget the part numbers but thats all they showed.So any thoughts? I Dont need the hard lines that go across the radiator. Just the hose and fittings that attach at the filter .
