OBDI/TBI engines are extremally limited in what you can do to make more horse power. The only modifications I did to my TBI crate engine was install a Comp Cams Computer controlled cam that increased the duration by 30-degrees, and the lift by 20-thousands of an inch. Have to go very little on the lift because stock GM heads have push in rocker studs, and cannot handle a whole lot of lift without pulling out the studs. My TBI was bored out 1/8", which increased the CFM from 480 to 620, and my adjustable fuel pressure regulator is set at 12-PSI. I was only pushing 9-PSI with my stock TBI fuel pressure regulator. All this netted maybe 20 HP and 30 FT Lbs of torque, which is not even noticable cruising around normally. The only good thing about my new TBI crate engine is I have a new engine that is going to last me for 200,000 miles.
