Hey guys,
I have a sbc 400 in my 77 blazer. When cold the engine runs good. Once it's up to running temp part throttle around 1500 rpm gets rough. Idle is fine and lots of throttle is fine as well. This was a smog motor and got all the smog stuff deleted. I'm assuming it has the egr quadrajet still on it. Could this be the root of my issue? I'm not against buying a new carb as this is a project. I do have a 700r4 and got the TVcable set up and don't really want to play around with that again tho lol. If anyone got any insite on this it would be great. Should i get a new carb? Play around with timing? New distributor.
Just to add to i bought this truck with the engine and trans already swapped on it. So I know nothing about what's been done or how used anything is. The distributor and carb i would suspect are as old as the engine. Which I believe to be a 79. So things might not be in perfect working order. I do know the vacuum advance works and the mechanical advance works as well. Haven't check to see if it's fully advanced tho. but this is a part throttle issue.
Thanks.
Thanks.
