Engine #'s
BurbLover
SW Missouri
Engine #\'s
I have my BBC on a stand in my garage, but having trouble seeing the #'s. Where exactlty should I look on the engine and once I get it, how can I get OEM info about it (original vehicle, year, etc)? Thanks.
EDIT: It's amazing what a flashlight will do!!! Anyway I found the following info/#'s on it:
Bellhousing:
3999290
CONV 1
GM9
I 20 71 (Found out means Sep 20, 1971 production date)
Front Pass Side of Block:
CE358413
So, can anyone decifer this for me?
Thanks!!
Re: Engine #\'s
mortec
Suffix code should tell you what you want to know.
nastyz28
Will help you deceipher your suffix code. I *thought* that number you listed last (CExxxxx) would be it, but don't see CE listed.
Re: Engine #\'s
Okay, let's see if I'm on the right track. I got this from the MorTec site:
3999290....396.......68-69...2 or 4 bolt, Truck
3999290....402.......70-72...2 or 4 bolt, Truck
3999290....402.......72......2 or 4 bolt, Passenger
I also found "CE" as a suffix code means "Crate Engine" or "Chevy Engine". This was used when the engine was either a warranty replacement or an aftermarket purchase.
I guess it's time to go back to Checker & find the correct water pump based on this info.
Re: Engine #\'s
HA! Thats pretty funny, my 402 is the exact same casting # and production date. Except mine was made in January '71. Cool $hit. /forums/images/graemlins/thumb.gif
Re: Engine #\'s
KidJethro,
Maybe you can help me out. I can't seem to find the correct short water pump for this. Do you have a short or long & what year/vehicle do you use when you get parts?
I am assuming that since the casting #'s are the same that the blocks would be identical.
Thanks.
