derek.cobia
Registered Member
I have a 1989 K5 Blazer. About a month ago, I installed headers for dual exhaust. I pigtailed the o2 sensor wire, which threw the check engine light regularly - understandably so as 1) it was pigtailed, and 2) exhaust pipes weren’t installed. Aside from the check engine light, I’ve probably driven it 300 miles+ with no exhaust pipes and I’ve experienced no performance issues.
Fast forward to today - I had exhaust pipes installed from the headers back, ending with the muffler. The rest of the exhaust from the muffler back will be installed next week. No cat.
When I was driving home, there was an obvious sputter when accelerating in lower gears...to the point where I thought if I were climbing a hill any steeper than the one I was climbing, I might to make it. The sputtering continued on flat ground but only when I accelerated.
The o2 sensor is a single wire sensor (and again, pigtailed). Given the fact that I’ve been driving with just headers and I drove it to the muffler shop this morning with no performance issues (over the same terrain), and given the fact that the muffler shop wouldn’t have had to disconnect any spark plug wires to install pipes from the headers back, I have to assume the o2 sensor is the culprit.
Is that a reasonable assessment? Is there anything else that may be causing this? And if it’s likely the o2 sensor, could tailpipes fix the issue or do I need a new o2 sensor? Are true dual exhausts throwing off the sensor or is it likely because I pigtailed the sensor and now I’ve got back pressure? If it’s the o2 sensor itself, would a 4 wire o2 with heat sensor fix the issue or should I just buy another single wire with extra long length?
The o2 sensor is mounted just behind the collector on the drivers side of that means anything.
TIA for y’all’s help!!
