Some sheet metal with the sides folded up should work then weld the corners together. The more i weld in school the more marks i will get and better practice, So im all out for fabing up my oh stuff. What about if i made the bottom completly square to add more weight to the other side ? And i think i am for sure make that adjustble shelf on itWhat he means is build one like this, and put a pan across the two legs. If you build a srontg enough pan it also makes a handy cart for transmissions, tranfer cases, and other heavy parts.
To bad ur in Canada, eh. The AC units they put on warehouses here had door panels that fit perfect. But you proly don't have AC up there...
