Engine stoped running
pomai
Oahu, Hawaii
my 88 full size blazer just stoped running while driving on the freeway. It turns over but wont start. the rotor points at the number 1 on the distibutor cap and the timing marks line up on the damper. Any ideas?
Thanks Ed
well i would start with spark and fuel.. if you have spark then check fuel supply. i have had that happen twice, first was fuel pump. other was ignition.
Thanks
Thanks, It turnned out to be the ignition moudule. Replaced it with a new one and started right up. Thanks again. Ed
