Engine to TCase Strut/ Fab Bracket to block?
uglytruk
IN A JUNKYARD, UNDER A TRUCK*N E Rust Belt
When I bought my '87 'Burb 6.2 TH400, I noticed that the right strut was missing. Closer inspection revealed the bolt that held it to the block was broken off in the block, and the other adjacent bolt was only able to thread in halfway, requiring a couple washers.
Strange 'cause the truck didn't look as if it had led an off-road type life. So I wuz thunking, maybe when I replace the trans with a 700, if I actually do it, I should fabricate a plate that bolts under both (right side) engine to trans bolts?
Anyone ever do that?
Curiously, the other side of the engine was missing the strut that connects the engine mount to the torque converter cover. I fabbed one out of a tire iron!
I've had a few of these trucks, and this ones the only one missing both struts, weird for a relatively stock, unmolested (but neglected) beast. Is it common to break the bolt out of the block?
Thoughts???
Here's me welding up a body mount/floor support. aren't self timers great/ amazing what u can do in the 10 second delay... put on mask, squeeze trigger... make sparks...
Thoughts???
You have some bad body mounts there, look at the body flex compared to your front bumper. :D
If you run it off road, the fan would hit the shroud. :doah:
uglytruk said:
That was when i was jacking the body off the frame to re-place mounts... jacked up six inches!
I know, that represents what would happen if you flex it off road, and that means your body mounts in the front are shot, maybe all the body mounts are shot.
:doah:
All mounts were REAL bad, rusted to death, washers broken, bolts half rusted away... Front, back, sides...yada, yada... But that was on the jack, but I understand... Didn't ya see the pix of me grinding, welding???
Now an oil lines pissing, and wifey wants to go accross the lake to Vermont, hope it holds out... 20f outside, but sunny... Andrew
