UPDATE: I started the truck and brought it to temp and I noticed something very peculiar; when shot with an IR gun, the Sniper bung and sensor that is screwed into to the intake, back by the distributor, read exactly what the gages in the dash read (155F). HOWEVER, when I shot the IR on the bottom of the tstat housing it read anywhere from 25 to 40 degrees hotter than bung and sensor near the read of the engine! I shot the front of the heads, the bottom of the tstat, rad hose and they were within 10 degrees of one another. When the front of the heads hit 200F I cut off the motor and could hear water boiling in the rad. I shot the rear bung and sensor again and it was almost 35 degrees cooler still. So BP71K5 I think you are on to something with a combo of placement of the sensor and Sniper being goofy. Back to the bung... I shot the rear Sniper bung and adapter and got another interesting read; the intake right where the bung connects read 177F, the adapter directly above was around 165F and the actual top of the sensor was around 155, the same reading as the dash gage. So what does that tell me??? Do I have air trapped in the system? Is the adapter lifting the sensor out of the fluid? Why is the rear of the motor so much cooler than the front of the motor? Is it because the cold water from the rad is dumping into the block somewhere near the rear of the truck keeping it much cooler than near the tstat/where the fluid exits the motor? Exercising this theory I should move the sniper bung to the front of the intake so that it gets a temp reading after water circulates through the block prior to before?
