@K85 Octane
Yeah, mine is single too, just 3" diameter. And even with the dropped "mock up" position, the CV has only about 1/16 clearance with the front axle in straight drop (hanging), much less articulation. It's going to still need some mild clearancing on the tabs. If it stays (roughly) and works where it is, it will have a set of one piece full width spacers before real trials begin. And thanks for the update on your brace. But I wonder how you have clearance. If my case were clocked up, that would be going through the floorboard by my reckoning, or do you have it clocked down (for the same reason as my drop)?
@Tnsejed
Thanks for the reference running without for years. I've seen that before too, but always wondered if that was a "it's ok, until it's not" scenario. With many miles of unimproved roads awaiting in my imagination, there's going to be a lot of rough use even without rock crawling. And I like to imagine I'll be more proactive than to let the slip become a problem. It also has an accordion cover on it (desert use, not mud, at least very often). But I haven't heard of breaking the bolts at the bell housing. Mine has a G8 bolt there, but that just means it would likely break out of the block first.
@Tnsejed
