Engineers? - Passenger side tcase brace function
Guessing yes, but are the bolts long enough?
Accidentally ended up with the wrong bolts on the 14sf diff cover (think maybe I swapped them with ones from a 10b) and they just kept coming loose. How critical would you figure that to be for that application?? But longer bolts solved the issue completely.
I always go with the longest bolts I can fit without bottoming out for that reason
Thread locked studs and thread locked nuts for the win.
Here are the final pictures as promised.
You realize the second pic makes it look like you mashed the pipe to half it’s diameter. :rotfl:
Not sure, are you talking about the perspective taper as optical illusion? :D In any case, it's 3" from turbo all the way to the tip of the tailpipe.
