ep381 fuel pump noise
brans87
- In Memoriam -
North Carolina
I just installed a ep381 fuel pump from rock auto in my 87 K5. Now when I cut it off you can hear it making alot of noise for up to a minute after truck is turn off.
Any ideas? I did use new pump and rubber hose that came in kit.
A bunch of noise? Is that the pressure forcing it's way back through the pump? What's it sound like?
I wouldn't disagree about the power being an issue, if the fuse is easy to get to, pull it when it's making the noise and see if it stops.
