ESC Electronic spark Control SES msg
Kyle89K5
OKLAHOMA
My 89 has been acting up a LOT here lately. I'm running a factory TBI350 with NO changes. When I go to get on the gas, especially when cold, it does nothing. Doesn't really sputter, just nothing. Well I guess thats not true. Half the time it dies. When it doesn't and I can pull it out, it pings a little then starts running okay again. Also, when I'm on the highway at around 65, it will just cut out. I thought for a while it was fuel, but I'm leaning more towards spark now.
This morning, I got a SES light when I checked the codes, it was for the Electronic Spark Control Module. None of the local parts houses have this part in their computers. Anyone got an idea of what ELSE it might be called?
I'm thinking that a change is in order on the plugs and wires, especially since this is a motor w/ less than 10k miles on it. Before the new motor went in, I replaced all the sensors the cap, rotor, plugs, wires everything. When the new motor went in, it got new plugs, but the rest stayed.
Any ideas?
Thanks...
If you are getting a code 42. My best guess is you have either a bad magnetic pickup coil or dist module. Bothe of these are in the distributor.
The electric spark controll module( flat square box located next to the TB on pass side) usually doesn't cause too many problems. They are usually a dealer item and cost $$$$
Check the dist module and pickup coil first before replacing anything else.
I replaced both of them to no avail...
Dealer only, Dang, I hate to hear that.... /forums/images/graemlins/frown.gif
is it throwing code 42 or 43? Mine used to throw 43, and I think my timing was a little too far advanced, if i got on it, it would ping, and the SES light would come on. I have retarded the timing since then, and it doesnt happen anymore...now its throwing a code 42 though...hopefully someone will know what causees this. any btw, the ESC module is the same as the ingition module.
Code 42 /forums/images/graemlins/frown.gif
It's going into the shop tomorrow so the guys that put the motor in can give me some feedback as well. I just like to try and get a little info ahead of time /forums/images/graemlins/laugh.gif
Thanks for the replys guys...
My dad just had the exact same symptoms in his 89 blazer totally stock. He put a new computer in it and it took care of the probs. I know they don't usually go bad, but I'd say thats your problem since you've already replaced most of the sensors.
Ben 87 Jimmy + 89 Blazer
/forums/images/graemlins/usaflag.gif
[ QUOTE ]
[/ QUOTE ]
Changed that to0 /forums/images/graemlins/frown.gif I'm up for about anything though. I'm hoping that the shop has some more imput tomorrow. Thanks for the replys though...
Befor you change any thing I have found that cleaning up the ground Wires that ground to the DIS, ESC,Igniter or Block can sometimes result in a correction. I have chased the parts before it can get expensive. /forums/images/graemlins/burb.gif
[ QUOTE ]
[ QUOTE ]
[/ QUOTE ]
[/ QUOTE ]
Are you having any other weird problems like your gages bounce when you use your turnsignals....Dim tail lights, weird junk?
If so make sure the ground strap from the back of the passengerside head to the firewall was put back on. That causes a tone of problems and sence the ECU grounds to the body.......... /forums/images/graemlins/blush.gif
Yeah. Speaking of grounds.When you put in the new engine. Did you hook up the ground wire that goes from the engine block to the body?
Not havin a good engine ground can screw things up.
Grim. its Twilight Zone time again. /forums/images/graemlins/shocked.gif
Check out the time on our last posts.
The omnipresent CK5 mind strikes again
/forums/images/graemlins/grin.gif
Grounds hooked up. That's one of the first things I checked.
Their's really nothing else odd going on. Everything seems to be working normal (except for the T-case which is grinding /forums/images/graemlins/eek.gif )
I had a shop put this motor in, and it is still under warranty, so they are doing the checking now. I spent about 2 hours last night checking all the connections and cleaning things up. It is now running exactly the same. /forums/images/graemlins/frown.gif
I'll let you guys know what I find out...
Thanks again.
[ QUOTE ]
Wells: ESC100
$57.99 from Autozone
[/ QUOTE ]
/forums/images/graemlins/eek.gif YOU ROCK MAN!!! /forums/images/graemlins/thumb.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/thumb.gif THANKS!
No problem. I knew we carried it because I checked into it when my brother was having problems with his truck.
When I had a code 42 it was my knock sensor, replaced it and all was well, no more pinging.
[ QUOTE ]
[/ QUOTE ]
MUDFROG nailed it. It is actually a combination of a few things. The knock sensor was the culprit though.
Now, that being said, I have a REALLY weak fuel pump that is causing some problems, and I may go ahead and change out the ESC just for peace of mind...
Thanks for all the input guys.
