bp71k5
3/4 ton status
So I took my new TBI motor out for a test drive today. It seemed to do pretty well at first except for a stumble every once and a while when the engine was under a bit of load and I had just shifted to a higher gear. The longer I'd drive it the more it would stumble. Enough so that I had to idle it back to the house in second gear. It idles consistantly with no trouble at all.
I found one possible cause was before my test drive I changed the base timing from 4 BTDC to 0 BTDC by just twisting the distributer a bit to what I thought was close enough. After it was running like crap, I checked it again and discovered it was at 4 ATDC. (retarded).
So I reset it back to 0 with the timing gun, but I didn't pull the fuse for the ECM after I made this adjustment. In fact the ECM has been connected to power since the motor was first started and I was tuning it.
After I went for second test drive, I noticed it doing the same thing and found the SES light was on and it's reporting 3 codes. These could have been set from the earlier problems I had:
1. 24 -No VSS signal (because I haven't hooked it up yet)
2. 42 and 43 which are the ESC and EST functions. I've double checked the wiring and they appear correct.
One additional bit of info is that the park\neutral switch wire is not hooked up to anything. Since I have a manual tranny, I wasn't sure what to do with it until I got a new chip burned.
So the big question I have is:
Is there way to test the ESC module or the EST (in the distributer) to determine if they are working correctly. The distributer is brand new, but the ESC is used.
I've reset the ECM and will try a test drive in the morning after the neighbors have left.
So I reset it back to 0 with the timing gun, but I didn't pull the fuse for the ECM after I made this adjustment. In fact the ECM has been connected to power since the motor was first started and I was tuning it.After I went for second test drive, I noticed it doing the same thing and found the SES light was on and it's reporting 3 codes. These could have been set from the earlier problems I had:
This problem feels just like it did before I set the base timing and it was far too retarded.
