The EST (Electronic Spark Timing) connector tab has broke off.
You know the piece? That brittle plastic tab you lift up on so you can pull it apart to set your timing?
It is now just a plug and play setup. Is there a replacement for this or can you make your own connection?
There's one on ebay but it says it's for a 85-92 TPI. Will that work?
out of it
