When I disconect the EST wire, the motor doesnt want to stay running. I can't keep it running long enough to set the time. Any ideas as to why this is happening. The chip is from Tbichips.com
So I set the timing to 20 degrees with the EST wire conected.
Thanks, Ed
Engine is a late model factory roller 4 blt main block, 383 rotating assembly, scat crank & 6” rods, Probe forged pistons. World S/R torquer heads. JBA shorty headers
Cam is a Roller Comp Cam 08-302-8, .480/.480, Duration 264/274, Lobe Separation 112.
1.5 roller rockers
Throttle body bores are 2” by Xtreme-FI from ebay along with there intake manifold bored the same.
MSD Distributor and Coil.
3” Cat Back Exhaust system
Delta Flow-Master
Thanks, Ed
1988 Chevy Full Size 4x4 Blazer
1.5 roller rockers
Delta Flow-Master
