EST Wire
pomai
Oahu, Hawaii
When I disconect the EST wire, the motor doesnt want to stay running. I can't keep it running long enough to set the time. Any ideas as to why this is happening. The chip is from Tbichips.com
So I set the timing to 20 degrees with the EST wire conected.
Thanks, Ed
1988 Chevy Full Size 4x4 Blazer
Engine is a late model factory roller 4 blt main block, 383 rotating assembly, scat crank & 6” rods, Probe forged pistons. World S/R torquer heads. JBA shorty headers
Cam is a Roller Comp Cam 08-302-8, .480/.480, Duration 264/274, Lobe Separation 112.
1.5 roller rockers
Throttle body bores are 2” by Xtreme-FI from ebay along with there intake manifold bored the same.
MSD Distributor and Coil.
3” Cat Back Exhaust system
Delta Flow-Master
If you turn the dist. so it will run when you unhook the EST wire, you will be able to time it the right way. It's impossible to time it with the EST wire connected......accurately anyway.;)
