During the build of my 1991 V3500 I have tried a couple of things that I thought where going to be an improvement over the original design that GM engineers made only to fail, and have to take it back to the original GM design.
Right now the issue is the coolant temp. I thought I was going to be slick, and put water restrictors into the thermostat housing, in order to do away with thermostat failures I have had in the past on some of my other trucks. The problem is that my coolant temps are all over the place. One minute the truck is running at 200 degrees while idling at a stop light in the sunlight, then 20-minutes later as the sun is going down and I am driving down a hill the coolant temp is at 150-degrees. My OBD-I/ECM is probably going nuts trying to figure that much temp fluctuation out. I am going to put a thermostat back in, so that I can get more consistent coolant temps. The OE thermostat is supposed to be a 195-degree thermostat, but I was thinking of trying a 180-degree one first, and see how that works. Any thoughts or suggestions?
Moroso Water Outlet Restrictors. I have the blue one in it now.
