Exhaust gasket help
apache
Central coast of Kali
Anyone know for sure which type gasket is used between the end of the manifold where the actual exhaust pipe takes off,it has 3 studs and flange holding it to the manifold also. Id imagine its either a "doughnut type" or a flat 3 hole triangle type gasket but not sure. It was dark and I couldent get it apart to see well enough. This is on a 85/ 350 /4wd Burb.
Thanks much guys.
