Well, its a 94, so not sure if its different.
Theres some stupid little support bracket that goes to the back of the alternator, its black. It is bolted on top of the studs on the manifold. It is bolted to the back of the power steering pump reservoir. I weaseled the nuts loose on that bracket alone, but there was not enough clearance to remove it. So i had to remove the PS bracket, which cannot be removed w/o removing the pulley.
I bought the puller (no one local had one in stock to rent), but i'm pretty sure it just that, a puller. No provisions for reinstalling.
In terms of pressing it, i meant use a bolt down teh shaft of the pump, to pull itself back on. I read some little blurb about doing this somewhere, but couldnt' make sense of it.
hmm.. looks like i might need this:
http://www.amazon.com/OTC-7005-Steering-Pulley-Installer/dp/B0002SRF8K
I was going to try and do it with a 3/8 16 bolt and a washer.
