Exhaust question
badmix
West Virginia
I want to be able to use my rear window, you know, put it down, without killing myself from fumes. Ive got 2 1/4 duals running out the back. Ive got 3" collector on my header. What would be the pro and cons of just running 3" single pipe (w/ catco cat and flowmaster muffler) and exit to the side, behind the rear tire. Is it worth it? What kind of sound would I end up with. Motor is 305cid stock.
I've got my exhaust exting behind the rear tires on each side. I have no issues with fumes getting in, moving or sitting still.
If you plan on running a 3" pipe from each header back...that is way overkill for a stock 305. A y of the two headers into the 3" pipe would be the way to go.
I have 2.5" (IIRC) from the headers to behind the transfercase where the "Y" comes together into a 3" single with cat and a flowmaster knock off (equivalent to a 40 series IIRC), exiting behind the rear driver's side tire. I can't comment on fumes but, the sound (stock 350) is great! Nice and rumbly, sounds like a muscle car! I could wish it was a little quieter for crawling though (makes it a little hard to hear a spotter).
My duals are straight out the back and the fumes are killing me. Running them out the side is really that effective?
Yes
The air behind the truck is a negative pressure when moving. When the window is down the air/exhaust gets sucked back into the truck. If the exhaust exits to the side, it won't/it's harder for it to come back into the window. I've heard having one of thoes spoilers on the top can help with this.
I'm in the same boat with a 350 though. The current exhaust has way too many holes and longtubes are sitting in the garage.
After reading around here I'm planning on 3" ypipe, no cat and exit behind rear tire.
What would you guys recommend for quiet yet free flowing and no cackling muffler?
