Exhuast Idea...
84gmcjimmy
1 ton status
B.C. CANADA
Okay, I hope this doesn't sound stupid, but in some pics I've seen I have seen trucks that are in deep water, and they're exhaust pipes get drowned by the water. So since my blazer is going to be my bogger/rock crawler, I was thinking sort of a custom exhaust set up- routing it up as high as I can, and then when it gets close to the rear have it pop up from the bed, into above/below where the taillights are. Then they would be fairly high to stay away from water if you stall.
The only thing I don't really know is how high I can get it up with all the drivetrain and being narrowed eventually. But if it went along the frame, and at the very end, come up through the bed, and curve out into where the taillight mounts like I said, and come out 2 inches or so from there. This may sound bizarre because I haven't been under the trucks for a while, so I don't know where all the drivetrain is for the routing of the pipes. What do you guys think?
sounds pretty tough, it would look badass, kinda like those old mustangs withg the exaust coming out of the rollpan, its always cool to do suff nobody else does, if you can pull it off go for it /forums/images/graemlins/peace.gif
Why would it look bad? You can hardly see it, the only thing you can see is the 2 openings of the pipe above the tail light /forums/images/graemlins/dunno.gif
bad ass like in good dude good idea go for it /forums/images/graemlins/waytogo.gif
that would be realy easy in a truck and it would look
BAD ASS /forums/images/graemlins/histerical.gif
but under a blazer it might be tight /forums/images/graemlins/dunno.gif
Yeah that's what I'm thinking. Today after work I am going to crawl underneath and see how much room I would have... then I also have to remember the doubler will be in there eventually.
Why waste time doing that when you could just run zoomies. /forums/images/graemlins/whistling.gif
[ QUOTE ]
[/ QUOTE ]
Or big ol fat stacks coming straight up and out of the bed! I'm thinking about routing my exhaust in the Blazer straight out of the wheel wells before the rear tires so when I'm in snow the heat from the exhaust will melt the snow from my tires for more traction. Plus when I pull up to a ricer I'll be able to melt all the plastic body panels off /forums/images/graemlins/blush.gif /forums/images/graemlins/weld.gif
come on, you guys know alot more than me, you must have an input to if this will work or not and if you have suggestions for it!
zoomies are the type of headers used on top fuel dragsters, mud boggers, etc. Either sticking out the side, or up through the hood.
oh, I can't do that:
out the side would be just asking for a rock to hit.
out the hood would be killing my vision /forums/images/graemlins/dunno.gif
My vote stays for stacks through the bed following the sides of the cab. Make sure you get the nice chromies with the stainless heat shields so nobody gets burnt /forums/images/graemlins/grin.gif Here's a link stackage!!! bling bling
I can't have stacks- I have a k5. And they look to industrial for me /forums/images/graemlins/dunno.gif
For some odd reason I thought you had a pickup... /forums/images/graemlins/screwy.gif The only real way to route the exhaust on a blazer is to go straight back between the frame rails until the frame bends up for the axle, then bend them outside the frame and exit. For your idea there would be a lot of very tight bends and the heat from the exhaust would melt the plastic for the tail lamps. I'm going to turn my exhaust out of the frame right before the wheel opening and turn it down at a 45*. My other option is just to have open headers and turn downs, but that's highly illegal in this state /forums/images/graemlins/whistling.gif
Yeah I need to look at it for space. With all the tight bends it will start to restrict the flow of exhaust. I may or may not do this...
Taillights don't matter, this is a trail only rig. If they melt, I'll buy some red plastic and put it over the light bulb... boolaa-instant tail light /forums/images/graemlins/dunno.gif
[ QUOTE ]
[/ QUOTE ]
I actually meant the plastic that holds the light in will melt. Unless you plan on using a snorkle, having the exhaust that high is kind of pointless. You're more likely to have water enter the carb than the exhaust /forums/images/graemlins/dunno.gif Build a snorkle first /forums/images/graemlins/wink.gif
