So If you have been reading the forums, I have been rebuilding my 396 big block. Just got the heads on today, fresh from the machine shop. Have been struggling with the rocker arms, but got it all figured out, and as I was checking the clearance of the valves on the compression stroke.... Look what I found.... Any suggestions, or anyone out there with a set of big block heads they want to get rid of? Preferably aluminum this time... Also, would it be wrong for me to go burn down the machine shop that let this slip past them? (found this first one, then realized its the same on 4 other spots).
