F*ck me
Well, my .02 cents, take them back to the machine shop and point it out, get your money back, and take it to another machine shop. Good thing you caught it when you did. If they missed this, why would you let them touch them again? That inexcusable in my book. I don't have any experience in chevy motors, but a cracked guide is just that, a cracked guide.....
Ok, here i am. I left him a PM already but i guess should leave a response here as well for any others that ever have this issue.
Basically that crack won't hurt a thing and can be left alone assuming the valve guide clearance is good. On BBC heads the guides are changeable and the intake is easy to change, the exhaust guide on the other hand goes through a water jacket and can sometimes be a pain to change a guide and not have water leak past the guide. I ALWAYS pressure test a BBC head that i've changed an exhaust guide on just for this reason. The exhaust guides are also different sizes along its length and MUST come out and go back in from the correct direction or you can crack the head. ALWAYS use a sealant on the exhaust guides when installing them but its not required on the intakes since those don't pass through a water jacket.
Like i explained in my PM to the OP if these heads came into my shop i would have tore them apart and cleaned and inspected them and then if the guide clearance was good i would then call the customer and let him know that the guides are cracked and that they could be left alone. I then let the customer decide what he/she wants to do. If moneys not an object then by all means replace the guides but if things are tight they can be left alone with no ill effects.
Thanks for posting your opinion Scott. Myself along with many others assumed this was disaster waiting to happen. Even though it may be ok to run like this, the machinist should have contacted the owner to give options as you pointed out.
Would the head casting keep this crack from extending itself?
Yes, that crack wont go anywhere from where it is now. Like thunder said, that crack usually gets there from a bent valve and no other reason.
