Now we argue about whether it should keep the factory drum brakes, or convert to disc. Then we need to know which master it uses...
-- A
-- A
When the table is sitting in its place, the tires won't be on it. When you want to move it, jack it up, put the tires on and roll it.
We're looking into making a 8 lug rim into a solid tire like a forklift might have. There is a place not far away that can do it.
-- A
Well of course it will have DIY4x4 disc brake caliper brackets on it.![]()
set spindle hight just right his air in/out trick would work super .
air in fills up and gives clearance . air out drops down on resting pads.
How were you going to mount the wheels so that they could be removed and avoid the tool boxes? That sounds like a PITA???
I had planned on lug nutting them to the 14BFF hubs.![]()
ok sorry you just lost me at post #45. I'm sure whatever you end up doing it'll be a good deal.
link it with air bags, plumb it to shop air to raise it up, dump the air to set it back on it's feet. it doesn't need to flex so the link geometry doesn't had to be anything special.
like these drilling rig tank / trailers .
when not hookd up / tilted the wheels don't realy do a thing . but when you pick up the trailer to the truck king pin the wheels come in to play .
