Fabrication table build
nice piece Kert....would have been nice to have for the SERE frame?
So, still quite a lot to do. We will get an axle under it yet or possibly just some spindles and hubs rather than an entire axle.
Plans for some tool boxes under the long sides as well.
So much room for activities :thumb:
how you gonna dimple die that thick of metal?
Put the table in to use for the first time today. Stripping this 14BFF, its spindles and hubs will be donated to the table for easy moving.
Interested in seeing this setup to move it. I assume you're cutting off the 14FF axle spindles and rewelding them to the vertical table legs and will mount wheels to move it as required. If this is correct will you weld the spindles inboard or outboard?
Outboard. I am to old to be climbing under there to put wheels on.
So tires will be just touching the ground when table is on ground, and then when you lift it up it will put weight on tires? Cool :D
When the table is sitting in its place, the tires won't be on it. When you want to move it, jack it up, put the tires on and roll it.
We're looking into making a 8 lug rim into a solid tire like a forklift might have. There is a place not far away that can do it.
set spindle hight just right his air in/out trick would work super .
air in fills up and gives clearance . air out drops down on resting pads.
