I do not recall ever seeing just the cable ends (lug) available separately ,but the Standard/Blue Streak battery cables we sold had the proper OEM style lug on them..
I have used one of these connectors on my trucks when I made battery cables from welding cable before ,at the solenoid end..I just smothered it with silicone caulk to keep moisture out..
I don't know if you will find the factory style with the little locating tabs on them. You can get regular 90 degree cable lugs and you just line them up where the need to be and tighten them down.
Yea I wasn't able to find them through my Google search but figured someone here might know. I did find the regular bent ones so I might have to go that route.
