I keep forgetting to post this, finally remembered when I have a chance.
Ignoring the disk brake craziness, when swapping a 14SF into a 1/2 ton (as I have) rear braking is too much. I admit, I know little about any variations in brake calipers that were used. I suspect at least one tons were all different, but beyond that, no idea if all 1/2 and 3/4 were the same, different, etc.
Since I have the parts catalog (although apparently they are finally in PDF online now) I'd like to look at all the various components, and see if GM took the time to match masters/combo valves/calipers/wheel cylinders depending on the various brake setups, or if perhaps in some cases the master was the only difference.
I know the RPO's like JB7 and so on, but I guess the starting point would have to be, were "small calipers" used on the front, with larger-than-10-bolt drums in the rear? If so, what applications and maybe what RPO?
Obviously I'm looking for a setup with 1/2 ton calipers in front, with the 14SF in the rear....of course I don't know the diameter on my 14SF drums, but they are 5.25" deep vs. 4" on the 10 bolts. Edit: Looks like 6 lug 14SF's were all 11" drums, which I then have.
I also know I *could* use the smaller 10 bolt wheel cylinder with these brakes, but I'd rather swap the master than mix and match cylinders.
