It's how I make rear disc setups work without a proportioning valve. I put the biggest caliper on front, and the smallest in the rear. Then I don't even touch the master cylinder.
Martin
Martin
There are different sized pistons in the different calipers. It's like a 350 and a 400. Same outer dimensions, different inner dimensions.
Marion
That makes sense, so get the proper backing plate for the larger piston caliper. So pad to rotor contact would be correct.
I have the exact same problem. Upgraded to a 6lug 14bsf rear and now the rear locks up pretty easy.
Correct, i don't know why either. That's why when you replace brake related parts, when prepping your axles. After you have it figured out that all is correct. Save that info for future replacements.Either backing plate should accept any of the caliper options. Externally the calipers are identical. The backing plate just needs to match the hub/disc that you decide to use (8-lug hubs have slightly larger discs than 6-lug hubs).
I still don't understand why GM simultaneously used two different backing plates that are so similar. When I placed mine side-by-side it looked like the difference between the caliper placements was a small fraction of an inch. Was the slight size difference worth the hassle?![]()
Nope, you want to use the half ton caliper mount with the half ton rotor, and the three quarter ton caliper mount with the three quarter ton rotor, any of the three calipers will work just fine with either set up.
Martin
If you put the correct rotor and caliper mounts together it will put them in the correct place.
Martin
Is this not what I said?![]()
