I need some info to satisfy the vehicle inspection, and safety check.
The door sticker shows: 31x10.50x15 Tire and 15x7 Rim.
The RPO code sheet in the glove box is partly readable, but the vehicle has
quad shock absorbers in front and I guess it is born with off-road option.
The tire size indicate factory option for off highway use and mods to
accommodate large suspension inputs.
Am I right?
2" lifting blocks mounted between rear axle and leaf spring, looks like the
same age as the rest of the vehicle.
Can those blocks be a part of some factory installed off highway equipment?
The vehicle did not pass the inspection due to the inspector's remarks:
Framelift with blocks. Remove blocks.
What is exactly riding height, front and rear measurements.
I have original shop manual and unit repair manual, no info on height.
I guess this forum has tons of high-tech users that can help me out.
Regards Carl.
Am I right?
Regards Carl.
