OK, I tried to post this earlier and had some puter issues I guess.
I have the factory tach and small fuel guage in the 90 VSS cluster. Having a good look at each one I figured it was the easiest way. I traced the circuits on both PC sheets for the fuel guage and found enough similarities that I took a chance and wired the guage directly. It worked, I had the small fuel guage wired by itself to the wires i identified and it read what it should read.
I did some creative hacking on the cluster body for the small fuel guage, and also for the tach so the wiring for the tach could come in from the rear. It's a seperate 3 wire harness. Ground, keyed hot and tach signal.
The donor truck I got this from was all hooked up and I didn't see any splices...except on the tach signal wire where there is what looks like a condenser. I "assumed" it was a noise filter.
So here is what it does when the engine is running. It reads higher than my ear tells me it's revving. High cold idle the tach shows about 2800 rpm, eventually settling at 1700 rpm after 5 minutes. My ear says roughly 700 rpm after 5 minutes.
Rev it up and it gets weird. Steady increase in throttle watching for full range of the tach. Tach goes up to 4000, then drops down to 3000 (as R's are still increasing) and then continues upward to 4200 or so...at this point my ear says true revs are between 4000 and 4500 rpm. As I let off the throttle it does the reverse.
I'm going to remove that condenser/filter and see if things change at all.
Anyone have experience with these old factory tachs? I'd sure love to have this work somewhat correctly.
Rene
