Factory tach
Mastiff
Tucson, AZ
I never realized until today that there was a factory tach option. In my cluster I have a giant speedo and fuel gauge, and small clock, oil press, temp, and volts. How is the tach cluster set up? My guess is the fuel moves to a small size, taking the place of the clock?
I've had a cheesy sunpro tach clamped to my column for years. Putting it in the cluster would be nice.
fyi that's for 80-up design gauges and from c-40 and up size truck hence the gas gauge in the middle bottom .
its the way I would do it also and gm should have done it for the light duty truck . :popcorn:
So it was a factory option with the tiny fuel gauge? Cool.
I cruised that thread you linked, but didn't see a pic of the whole cluster. What do you lose to get the fuel gauge over in the set of four small ones?
blank / idiot light / or clock is 1 of the item to loose .
there is a few good write-ups with pics in the garage with how to modify and add factory tach .
What idiot lights do you lose on the bottom of the fuel gauge using the C40+ truck tach?
Only real downside I see, but most probably don't care.
