I just priced it out on Randy's Ring and Pinion site and it came to over $2,000 in just parts with no shipping or taxes. That is assuming a 10-bolt/14 SF axle combo in a '91 Sub, 4.56 gears front and rear, Detroit rear, Lock-rite front, and install kits for both axles. I used the "mid grade" option for the gear sets (not the $600 OEM versions!). You could save maybe a $100/axle with the cheaper gear sets, probably okay for the front but wouldn't do it in the rear on a DD.
Just the Detroit and Lock-rite are over $1,000 and then add in the cheap gear sets and the bare bones in bearings and seals and you are hitting the $1,500 mark on just parts.
My recommendations if money is tight....well, besides just not doing it to begin with
. Definitely skip the front Lock-right for now as that will save you the $300+ parts cost and I would guess most shops would charge a little more for installing it (there is still a little extra work involved in installing the Lock-right even if already doing gears).
Seriously consider going the military 14FF rear route, or at least look around for one. Haven't looked recently but seem to remember them going in the $500 range at some point in time. That is significantly cheaper then gearing and locking the 14SF and once the spring pads are moved you can bolt it in an hour.
