Felpro #1880 1 piece oil pan gasket
you need to stop what your doing and get an oil pump primer in that thing now and verify proper oil pump operation.. the tool is cheap, or you can pull the gear off an old dizzy too..
if you had 5 psi, than the pump is spinning, but somethings not right there..
