few scx10s and a wraith for sale
84CUCV
3/4 ton status
NJ for now
first up in my pretty much new wraith. Brushless tekin ROC 412 with RS PRO ESC venom shorty 2s 3800 mah battery. savox sa-1283sg high tourqe servo,rc4wd lowering shock mounts,front mount battery tray ,all aluminum shocks body cap and spring retainer,Mip heavy duty drive shafts,axial wheel weight kit ,hot bodys crawler tires, true bead lock wheels , stock axial wheels and tires, titanium links and steering link chassis servo mount included not installed. vanquish c-hubs steering hubs and rear hubs ,vanquish servo/ link mounts front and rear, aluminum axial servo horn.green strc diff case covers,aluminum. custom painted body panels and aluminum roof plate. will Include a new fly sky gt3c radio $670
scx10 crew cab. The chassis is an older RC4wd. All aluminum links. Heavy-duty aluminum lower links. Transmission is new from a vehicle parted out on eBay. Axles are completely rebuilt, new bearings, gears axle shafts. Up front is axial aluminum c and high steering knuckles. Outback is axial lockouts. Have the parts to convert over to 2 speed. Not in the picture. Never got to it. Steering servo is a CS-170 a New castle Sidewinder ESC. With the fly sky receiver $550
scx10 With a new bright Jeep body and a custom cage. Done very well. Bumpers are custom-made to. has a GCM chassis, motor mount and transfer case. Got this off year while ago. You sit a bit. Put on the shelf. As a new Tekin motor. 35 turn I believe. Steering servo is a hitec mg646 I think it is. aluminum Steering horn. Has a rear tire carrier. Solder came loose and popped off I have it. Just not back on yet. Pro line bead locks the chisel tires. Fronts have waight. Rears do not 550
Any questions let me know. I could put a radio with scx10 Jeep and a esc if you like I have tons of electronics. I'm in New Jersey. If you want to come see. Send me a PM.Have a good one
