84HOOLIGAN
Registered Member
If you could build your FF14 Bolt Your way, what would You do?
repack wheel bearings ? they are oil bath from the diff. not meant for full grease pack like front stuff.
Thanks for the correction, I misspoke...
14b from a buddy... Free...
4:56s out of another truck... Free...
Orb of Traction... Free...
Shaved with homebrew dif cover guard... Free...
Disc conversion... Around $50 IIRC...
Beer... Who knows how much was spent on this upgrade...![]()
More info buddy?
Like tire size?
Gear ratio ? what u have. what u want?
I run 4.56s for gears and since my rig wont be daily driven its spooled. If its a daily driver id say detroit. I run 37's with stock t-case so id like 5.13s for gears you know how to find me lol.
[/QUOTE]This funny, so the only way is to build it all out, then you say spool it for now then ARB later?Since i started this build ive found that there really is only one way to build a rig, that's all out.
With that said; as soon as I pick one up it's getting 5.13s, shaved, spooled(the cheap way for now, ARB later), disc breaks, and trussed.
Go big or go home, right?![]()
This funny, so the only way is to build it all out, then you say spool it for now then ARB later?![]()
