I know I’m going to regret this, but I’ve got to make some room in my garage. I’m selling all three together, essentially making your K5 into a pickup in appearance. No serious damage, the toolbox could use a fresh coat of spray paint to look ideal. You’re going to want to paint the fiberglass to match your truck, so the slight fading of the paint from the sun doesn’t matter. The window is pristine with the exception of the CB antenna, which you can remove if you’d like. The cover is also in excellent condtion, it’s been in my garage for a couple of years, so it’s a bit dusty. I’ll send closer photos of anything you request. Figured I’d put it up here first, since it’s more likely to go to a good home. Getting it to you is going to be the issue. I’m in Long Beach, CA. I make frequent trips to the Prescott, AZ area. We can work something out if you’re in between there. If not, I will work with you in whatever way you would like to get it to you. Possibly someone going go Blazer Bash can pick it up and take it there. I will also be in Lake Havasu the next two weekends, I can bring it that far if you’re interested. The cover was over 1000 new, the toolbox was 700, and I have no idea what the fiberglass is worth, I just know they are really, really hard to find. Based on that, I’m going to throw out 1500 for the three and see if anyone is interested. If I’m way off, please tell me….
