bp71k5
3/4 ton status
Nope no joke. I’d also recommend the saltwater chlorine generator. I’ve been happy with mine and have saved tons of money not having a pool service.I'm all ears. This madness has me considering going to a saltwater setup. So I'd be curious unless your setting me up with a joke IE visit the cat website to book a backhoe rental.![]()
If you’re using trichlor pucks or dichlor, those include chlorine stabilizer (CYA) that doesn’t go away unless you drain water. But it also lowers the effectiveness of the chlorine. Once the CYA builds up over time it takes more and more chlorine to keep algae away. A better way is to use liquid chlorine (sodium hypochlorite) which doesn’t have CYA. You can also use a saltwater chlorine generator to get the same thing. Then add the CYA separately so you can manage the appropriate level. A popular misconception is that a saltwater pool doesn’t have chlorine in it, but it does. The chlorine is just generated from the breakdown of NaCl with electricity.
They have some pool school articles here.
www.troublefreepool.com
