Finally a Wiring Harness for the 1973-82 Chevy/GMC Trucks! Pre-order Now!
ion
Dayton, NV
I am proud to announce the American Auto Wire Classic Update Series Wiring kits for the 1973-82 C/K Series trucks.
Price: $589.95
Order now to re-wrie your rig the right way!
Classic Update Kits give you one of the most complete kits on the market to “Make Wiring THAT
Easy”. They are designed for specific year, make, and model configurations. The 1973-82 Chevy/GMC Truck Kit is no exception. The kit boasts 12 features making it the most complete system
of its type in the industry including:
• A replacement headlight switch with internal 25-amp circuit breaker, adjustable length
shaft, and custom knob.
Standard turn signal flasher, hazard flasher, and horn relay mounted on harness.
• Fuse box designed to fit in original location with no mods to the firewall. All required
hardware supplied. New ATO fuse panel allows for easy fuse and circuit breaker
accessibility. Harness is laid out and formed to allow for nearly all after market
accessories such as; gauge packages, wiper systems, heat and air conditioning systems,
etc.
• Steering column connectors can plug directly into most aftermarket steering columns or
stock 1975 and up GM columns. Can also be mated to earlier columns using the adapter
and terminals included in the kit.
• Separate under dash courtesy lamp assemblies are also included for use along with your
original dome/interior lighting feeds.
• Instrument Cluster wiring is designed with a “cluster harness disconnect” system for easy
service and assembly. Original terminals and connector that will plug into the original
gauge cluster (another American Autowire exclusive) are provided. The system will also
connect into most popular aftermarket gauges such as DAKOTA DIGITAL, CLASSIC
INSTRUMENTS, AUTOMETER, VDO, and others.
• Rear body harness assembly plugs into the main harness at the main bulkhead
disconnect location and our longer leads allow for stock or custom routing of the wires.
Rear body wiring includes backup light lead wires and connectors along with stop and tail
light lead wires and connectors. License plate lamp lead connection, as well as the fuel
tank sender lead connection is also included.
• Original style lamp sockets and side markers for fleet side and original style molded
connections for step side rear lamps are included.
New floor dimmer switch is provided for ease of installation. Wire length and connection
accommodate original floor mount dimmer switch.
• Engine wiring includes feeds for coil, tach, water temperature, oil pressure, electric choke,
and electric speedometer (if needed). A heavy gauge alternator feed and fusible link are
also included for any typical high output 1 wire or internally regulated alternator.
Connectors supplied for power and tach leads for GM style H.E.I. distributors along with
various oil and temp senders.
• Front lighting includes extra long leads that can be routed for stock or optional
appearances. All head light, parking light, and directional light leads, along with a switched
trigger wire for an electric fan relay (usually recommended with AC) are provided. Mating
terminals and connectors are also provided for you to complete your custom installation.
• New parking lamp socket and side marker lamp sockets are also included.
Let's rewire those rigs and make it easy while we're at it!
Do you sell connectors seperately?
I rewired my rig about 10+ years ago with a Painless Harness but had to reuse my original front marker light/blinker sockets. Needless to say they are a little rough (original 1980 in the salt belt).
whats the Harness that Thebeast88k5 just got? is that a plug/pigtail for the gauge cluster?
The harness he got is only a universal gauge wiring harness. I have those for sale as well.
ok does it plug into the trucks existing plug? If not, do you have the opposite side that could be installed on truck side for ease of panel removal? And price? Thanks!
No it does not plug onto the truck's plug, Yes I supply another plug that will connect to the harness, so you find your wires in the factory harness and install them onto the plug that I provide.
100 bucks for this harness.
Sweet! Thanks for the response!
I say we move these harnesses off of the shelves and make room for new ones!
